Theres a thread from RFB complaining about something at least once a month.
another issue could be the mounting points for the exhaust. if they are hard points without insulators and dont allow any flex in the exhaust cracks and damage can occur due to expansion when the exhaust heats up as well as when the truck flexes off road. hard mount points will put stress on the weakest points and cracks will develop.
It uses the stock Toyota isolator cushions and stock frame mounts so it should move the same as the factory setup. The rear most mount on RFB's is in a different spot since his rear bumper covers the rear most stock mount.
pd 2000.00 drove 600 miles to have it installed in under 2yrs have had 11 separate issues, SS pipe shattering like glass (in Ouray) blown out header gasket 2 months after install. all gaskets smoked. now this. Anyone know of a exhaust guy, that will make it for real?? trucks sounds like S*&^ AGAIN over 800 in on the road repairs. Already had welders and exhaust guys look at it, and explain its the wrong thickness SS View attachment 2194377View attachment 2194378View attachment 2194379
Buy a kit from Magnaflow and build it yourself!
Exhaust Kits - Best Custom Builder Kits by MagnaFlow Exhaust Systems
Get the ultimate exhaust builder kits, custom fit to your car, truck or motorcycle with same-day shipping on ALL in stock orders! MagnaFlow manufactures the best exhaust systems, mufflers, pipes and catalytic converters in the USA using premium components and the latest technology.www.magnaflow.com
You already know you can get the front downpipe and cats from them.
A few years ago I bought a Magnaflow muffler for something I had in mind. Because I was aware that there can be cembrittlement problems with certain types of SS and incompatible weld fill wire, I called magnaflow Customer service to ask what type of SS alloy they use for the muffler shell. The best answer I could get out of them was "400 series" I think they tend to use that because it's much less expensive than the superior 304/316, while still allowing marketing to claim SS.Wrong type of stainless. It appears that the tubing is 300 series and the muffler is possibly something different. This can happen when shops are lied to by the people selling the mufflers. Watched it first hand when a shop outsourced their exhausts and the first couple batches were good, but then the overseas production started using cheap s*** products without approval.
If you want a truly lifetime exhaust have a shop build it out of 300 series, 304 or even better 316 and use a name brand muffler also made from 300 series.
I had done some of this research a few years ago.A few years ago I bought a Magnaflow muffler for something I had in mind. Because I was aware that there can be cembrittlement problems with certain types of SS and incompatible weld fill wire, I called magnaflow Customer service to ask what type of SS alloy they use for the muffler shell. The best answer I could get out of them was "400 series" I think they tend to use that because it's much less expensive than the superior 304/316, while still allowing marketing to claim SS.
The only way to solve this business is to not depend on possible brittle welds to hold up to long term thermal stress cycling in a high physical stress setting. The bracketing must be well designed with stress releaf in mind.
