This thread is geared more towards AHC folks but those with standard suspension might be interested too. I reached out to Sway-A-Way and they do offer custom T-bars for the 100 series.
I was suggesting maybe 27mm T-bars for those with added weight in the front but not so much to warrant the non-AHC bars.
Current price is: $490 for (1) pair. $410/pr for (5) pairs. Delivery is 6 wks after ordered.
From previous notes. Accuracy not guaranteed
AHC 25.5mm
OE standard, non-AHC 28.87mm
OME is 30.5mm
Sway Away: 31mm & 32mm (depending on availability)
Ironman 32mm
TJM 32mm
Hey wait a minute. Can’t any machine shop turn the bars to a thinner diameter? I’ve got some used non-AHC bars. Is it as simple as shrinking the diameter or is it some fancy metal composition thing??@krispykritter The person at Sway-Away I spoke with was Brian Skipper <brian@swayaway> and the pricing was from February 2023.
I read Sway Away can also turn down existing torsion bars to a smaller diameter. They offer them in 32mm, off the shelf for $329/pr.
Torsion Bar Set – Toyota F100, Land Cruiser (Late Model) & LX470 Gas – Sway-A-Way
Sway-A-Way's high-performance replacement torsion bar set for Toyota F100, Land Cruiser & LX470 Gas.swayaway.com
I called Sway-A-Way and spoke with one of their engineers explaining why the current offering (32mm) they sell are too large/too much spring rate for many of our needs.
I asked if they could make a set of bars in a smaller diamater (the answer, of course, is 'yes for the right price').
I would be interested in stocking these or in helping to bring a bar of similar spring rate to OEM Land Cruiser bars (can make 27mm and 29mm) for a much more reasonable price point (~$700 MSRP ea. from dealers)
Would anyone be interested in signing up for a pre-order so that I can bring the cost per set down?
Ditto, I'd sign up for a 27mm set if the price was right. I was expecting a little over 500 after inflation using @hoser original number.I would sign up for a 27mm ish bar tomorrow for the right price - I believe he told me $700 for a one-off set quite a while back.
I did all the math on this a while back and came up with 27.1mm as something like 60% of the way between stock AHC and stock non-AHC. I picked that stiffness as a total guess on my end based on how the 100 felt with the two torsion bars I've fitted so far. Once I had an idea of the spring rate I wanted, I used online calculators to come up with a diameter to match. Not perfect, but the Sway-a-way guy said my math matched what he came up with when I called. I, of course, have misplaced the spreadsheet where the math was, so this is all from memory =(
I can tell you that with AHC + OEM torsion bars vs OME 2860s, the front end is STILL noticeably stiffer than the rear. I would love to get some articulation back in the front end.
So you are proposing the King springs of torsion bars for AHC vehicles as well, or just deleted vehicles?
My best guess would be an ETA of later 2025 (probably fall) when they’re on my shelves. Obviously ordering in larger quantities will bring down the price but I can’t shell out $30,000 for bulk sets of torsion bars right nowInterested in an AHC set
Yes. Most likely identical or very close in price. The AHC variants will be milled down further than the stock bars which would require more machining time (which may increase costs). Will need to get a quote from X-SwayDo you expect the AHC upgrade bars to be similar in price to the non-AHC upgraded sets?
What is your front pressure? I wonder if backing the bars off some and adjusting your front pressure to the higher end of the range would take some stiffness out of the bars...
