If you could have a 4 or 6bt cummins in your 60 series which would you opt for? I know both have been done. 4bt is lighter and smaller but can rattle a bit. 6bt has more power, no rattle but larger in size and weight. Curious on people's thoughts.
you could also get an almost bolt-in Toyota diesel like a 1HZ
Yea the p pump is what you want. The hx30 spools up pretty quickly as well. I changed the governor to a 4k governor spring, makes a big difference. I'm not entirely sure about the mounts, They were put in while I was in Iraq but I think they are liquid. I wanted to clarify one thing, I changed out the rear axle to an 80 axle. I did it to get a full floater not because the 60 axle couldn't handle it.Yes the motor I am looking at using is a 4bta also with the inline pump (P-Pump). Probably try out the hx30 turbo first and if she isnt enough then bump up to an HE341 or hy35. I will also increase timing, fuel plate, gov spring the usual stuff... Should be a pretty fun truck to run once I get it done. Phoenician are you running the liquid isolators for mounts? For cost I cant find a 6bt in AZ for less than 3k but 4BT's 2500 all day long
Sounds cool, how bout some pics!Yea the p pump is what you want. The hx30 spools up pretty quickly as well. I changed the governor to a 4k governor spring, makes a big difference. I'm not entirely sure about the isolators, They were put in while I was in Iraq but I think they are liquid. I wanted to clarify one thing, I changed out the rear she to an 80 axle. I did it to get a full floater not because the 60 axle couldn't handle it.
If my egts are too high I will add a bigger turbo.
