- Thread starter
- #461
A couple more of the outlet placement.
You talking about the gas pedal linkage? Mine is an 80, so it's going to look different (I think).
Lol...thanks Dave. Sorry to waste your time, I forgot we had different injection pumps. The P-pump needs to be pushed from the pedal. Again, sorry to waste your time.
The P-pump throttle is universal. The lever can be mounted however you need it to work in any direction.
What often works well is to mount a plate on the AFC cover bolts to hold the throttle cable, orienting the throttle cable vertically.
: Not sure I understand this Doug."You graft the pedal bases together"
FWII starter bolts should be M10X1.5. 3/8-16 will thread right in and then strip out when tightened in an M10 hole. If they're really 3/8 threads that's weird!
Okay boys, I'm trying to understand the wiring for the fuel shutoff solonoid.
I have searched the 4btswaps sight a couple of times and not found an answer easy enough to understand for a dummy like me (I left an identical thread over there). I have a fuel shutoff solonoid with a wiring plug on it. There are three wires: red, black and white. Red is power? Black ground? and white is to the starter? I know a relay goes in here somewhere.
I would like to wire this to a toggle switch on the dash. So, the switch on the dash should go to a relay. What kind of relay? 4 post? 5 post? (I looked at both at NAPA tonight and no one knew) The relay closes to pick up higher amp power (Or the ability to pass more amps), which goes to the red wire? This would stay powered when the vehicle is running. So, if I have a 4 or 5 prong relay what is each prong wired to? 4 Prong (I'm guessing here), one to the dash switch, one to ground, one to battery, and one to the shutoff solonoid (Which is then wired: red to relay, black to ground and the white to the starter?)
If a wire goes to the starter, it would hook to the starter solonoid terminal, right. Certainly not to the terminal that the battery is connected to, that would provide constant power to the fuel shutoff solonoid. So, if it is connected to the starter solonoid terminal, wouldn't that be the same power coming from the keyed ignition? Would that power throw both solonoids? Or is it that the power from the starter then allows the shutoff solonoid to use the power from the relay?
Remember I'm an idiot when it comes to wiring, so use little words.
