- Joined
- Jun 21, 2011
- Threads
- 239
- Messages
- 22,373
- Location
- Redding, California
- Website
- trail-tailor.com
Now that's a set of motor mounts I-Man... enough said.
J
J
J
The motor mounts are looking pretty beefy.
In regard to how we set my engine (gm V-8).... We set it as high as possible and still allow for the hood to close, then made adjustments left and right to try and align square with the radiator and then allow for ps pump and gear clearance on the left frame rail
If you ever encounter the bearing problem again, like outer races on wheel bearings or the outer race of your pilot bearing, just lay a good fat weld bead on it. as the weld cools, it shrinks the race and it will fall right out. Seen it and done it. It's amazing.
I ground engine to frame, frame to battery(s), battery to body and battery to engine.
Ground the engine to the frame, same as before. I believe your shutdown solenoid is a one-wire job and so are some temperature senders. Certainly won't hurt to maintain all items at.the same electric potential for corrosion concerns.
That is how my 60 was stock, my Isuzu NPR donor was stock, and how I wired my swap. Can't have too many grounds in my opinion.
Cheap and easy to do.
Doug
X2 .. I have all 3 ( block / body / frame ) joined for better ground ..
Okay, so I'll ground everything.
Got the engine back in last night for the final time. I just need to refabridcate the tranny crossmember. I still for the life of me can't figure out why the adapter is configured so that either the engine has to be rotated or the transmission has to be rotated, or a little bit of both.
Anyone with a stock 2f and tranny, please look and see what direction your transmission tilts. I can't remember if it is left or right looking from the back. I'm just wondering how much I can tilt that Ranger, H55 and transfer case and still get proper lubrication.
I held the intercooler in place real quick last night and it looks like it will fit perfect, thanks Cullman. I just have to get it strapped in tomorrow and measure for the piping.
I was gong to have the radiator looked at just to make sure it is sound while I have it out, but my boss tells me we don't have a radiator repair place in town any more. Nice to live in a little town.
Looks maybe 5 - 7 degree's to me also. I left my trans angle stock on my swap.
The reason Toyota rotated the trans/transfer is to lower the output shafts and drive shaft angles. Have you checked these angles and clearance with the engine mounted yet? If you add a lift and raise the output shafts, you get into vibration issues.
Just something to check now rather then later.
Looks good
Doug
