cult45's 45 recovery and remobilisation (13 Viewers)
Love it, thanks dawg!
Brilliant work mate she's alive
Thanks lads. And thanks for your help!
Put my newer RTM on and relegated the worn one to the tray. The gave it it's first tub in about a decade! Might be getting my hands on a rad this afternoon. If so, tomorrow after fitment and proper timing it's drive time..
Hahaha shut up. With any luck I could be around this Sunday.. ;)
Wait, what?? ;)
Woke early this morning and got to work. Fitted the brand-new-in-2001 rad [that I got for a smashing deal!]. Popped two head bolts and installed the air cleaner bracket using my old Chinese torque wrench that I wasn't even sure worked [which is fitting, as this type of backyardery was the way this build began - and therefore end]. Tightened exhaust manifold studs to chase a small leak. Brought the flywheel mark in line with the bell housing needle and set the rotor button to #1 then hit the key to burp the cooling system and final timing adjustment. My torque wrench worked like a champ! No leaking head. No leaks from the rad. Backed the idle screw all the way out and reset the mixture screw to 1.5 turns off bottom [as per Shane's advice from the Aust 40 Series Landcruisers FB page and engine swap shed] and BAM - it runs like a top! No high idle to compensate for poor timing. Good oil pressure. Just need to get my damn temp sender and then I can go for a proper drive!
She's perfect now mate great work love the song choice and the vid fantastic
Thanks boys. Just a quick shout to y'all for all your help, check-ins and advice. Love this joint.
Very nice mate, that's one very big bump in a long road, which you've mostly got over now?
haha splendid! i had to watch it twice. gonna pull the lid off and fold the screen down while theres a bit of summer left?
Thanks lads! Literally couldn't have done it without y'all!
