prwillard2
Garage doorHow do you get into your domecile?
The garage door opener on the mirror. I guess it's not the most secure and I have considered upgrading my dead bolt to a smart lock on the front door. I guess it's on the "honey-do" list.How do you get into your domecile?
I am going through the ringer on the backup key. I have a 2020 LC, I ordered the CC key. However the back up key, it seems like folks who order 69515-30380 are receiving one without the triangle cutout - and it's not working. The pics online of 69515-30380 show no triangle. Can anyone confirm/deny if the key requires the triangle cutout?
69515-30350 Genuine Lexus Key, Master
Genuine 69515-30350 Key, Master fits 2007-2025 Lexus models. LexusPartsNow offers 6951530350 for $43.68.www.lexuspartsnow.com
See example - no triangle cutout.
My new to me ‘15 LX came with an all 3 keys including card key with the HYQ14ABB fcc code on the back (which seems year appropriate from my research) but it doesn’t work. It did have a similar but smaller CR2016 battery inserted (still 3V) but I replaced with a new, proper CR2412 and still no joy.
Is there any troubleshooting I can do with/without techstream (I don’t have a way to use it at the time but am looking into it)? Not sure what the failure rate of these cards over time is, but I guess I have to assume it’s not a dead card.
That’s wild - I tried 2x “fresh”, “new” Panasonic batteries from Amazon - should I return them and try a different set? The terminals are nice and clean as well.Before you expend a bunch of effort trying to program it - try one or two other CR2412 batteries in the card. In my experience the credit card keys are extremely sensitive to the strength of the battery and I've had plenty of "fresh", "new" CR2412s not work for no obvious reason.
I obviously can't tell you for sure whether the batteries are the problem or if you key card hasn't been programmed or just went bad or what - but I have had plenty of batteries that were sealed and "fresh" and "new" that card didn't like for some reason. Just mentioning it is worth a try. For me, programming keys on tech stream involves dragging an ancient Windows laptop out of the attic and trying to get it working again and I always loathe that process. Best avoided if possible!That’s wild - I tried 2x “fresh”, “new” Panasonic batteries from Amazon - should I return them and try a different set? The terminals are nice and clean as well.
you need to confirm that the card key is for your model year LX, i think you can find that information hereMy new to me ‘15 LX came with an all 3 keys including card key with the HYQ14ABB fcc code on the back (which seems year appropriate from my research) but it doesn’t work. It did have a similar but smaller CR2016 battery inserted (still 3V) but I replaced with a new, proper CR2412 and still no joy.
Is there any troubleshooting I can do with/without techstream (I don’t have a way to use it at the time but am looking into it)? Not sure what the failure rate of these cards over time is, but I guess I have to assume it’s not a dead card (for now).
I could order a couple more to try - just to rule it out. Yeah, I was looking into the "LAUNCH" handheld device that looks to solve the laptop techstream problem mentioned in another thread. Might be of interest to you!I obviously can't tell you for sure whether the batteries are the problem or if you key card hasn't been programmed or just went bad or what - but I have had plenty of batteries that were sealed and "fresh" and "new" that card didn't like for some reason. Just mentioning it is worth a try. For me, programming keys on tech stream involves dragging an ancient Windows laptop out of the attic and trying to get it working again and I always loathe that process. Best avoided if possible!
I dug through multiple threads that seemingly confirmed "HYQ14ABB" would work for my model year.you need to confirm that the card key is for your model year LX, i think you can find that information here
If the battery is low, you can rest the card key close to the ignition button and start the vehicle with it. If it doesn't work, to me that means it's a bad key card (or dead battery) or not paired with your vehicle.
In the past, I have moved key cards from one lexus vehicle to another by sending it out to get reset from this ebay seller here. Then using techstream to program it to the vehicle.
