Even with the auto trans you tend to spin the tires before you get traction, being able to turn the tires at a very low speed gives you a better chance of getting traction on rocky obsticles.
TiredIronGRB said:Even with the auto trans you tend to spin the tires before you get traction, being able to turn the tires at a very low speed gives you a better chance of getting traction on rocky obsticles.
Newb looking for info here:Nay said:...You don't have the same need for ultra low crawl gear with a large displacement engine and auto tranny as you do with a small engine and a manual. This is why in the Jeep world you tend to see low range reduction kits and in the Toyota world you tend to have the crawler boxes (the latter being substantially more expensive)...
Nay
psfpilot said:Newb looking for info here:
Am I correct in assuming the above post about the lack of need for a crawler box is referring only to the uphill side of things where the torque converter is effectively acting to further gear things down, and not referring to the downhill side of things, where the torque converter doesn't help to slow things down?
I think I want an extra-low crawler box so that I can improve my control through compression braking on steep downhill sections of both solid rock and scree.
The stock low range just isn't slow enough at idle on a steep downill, and when I use the brakes to further slow the velocity during descent on steep grades, I have to fight both gravity and the tremendous torque produced by the low range and first gear combo. It's actually easier to shift the tranny into neutral and use the brakes alone, but this makes it more prone to sliding on scree, hence my thought that an ultra-low range would allow me to descend in a more controlled manner.
I don't have any experience using a crawler box, so please speak slowly and use small words so that I will be sure to understand.![]()
Nay said:The advantage of a crawler box is that it adds onto your stock t-case gearing. If, as I have been advocating, you had a 4:1 low range kit, then you still have two gears in the t-case: high and low, and your max reduction is 4:1 (this would still help your downhills tremendously). Now if you add a crawler box with say a 4:1 reduction, then you have your stock 2.2:1 low range (or whatever the exact ratio is) for general usage, and you can engage the crawler for extremely low range of say 6.2:1 (or is it actually a multipler of 2.2 * 4???). So you now have 3 gears in the entire transfer case mechanism split between two boxes (4 Hi, 4 Low, 4 Low + Crawler).
A crawler (in essense second t-case) is how you get the ultra low gearing only when you need it, but the spend is much higher and to date requires physical mods to the chassis/gas tank. You also shorten your rear driveshaft so you will be replacing it.
If you are going to put out a crawler, it has to limit the mods to the vehicle to the maximum extent possible, and IMO, gas tank mods are entirely out of the question for anything designed for a mass market. I doubt most people would be comfortable even with having to cut a hole in the floor for the shifter and nothing more. A 4:1 uses that same little knob that you use today to shift into low. Somebody who gets this out on the market, if it is technically feasible, is going to make a nice chunk of change.
Nay
kirk said:Adding a crawler box seems like the best (excluding cost) option. low range gears are by far a cheaper route.
I have a 82 pickup with dual transfer cases and it is awesome. For the type of wheeling I do I need the factory low range in most trail riding conditions and the double low for the hardcore spots, even with 5.29 gears on 35's
ALSO, NOT TRYING TO CHANGE FOCUS OF THE THREAD BUT WHAT IS MARLIN'S OPINION ON THE 80 SERIES T/C GEARS VS CRAWLER BOX ISSUE??
PKP80 said:well who wouldn't want 1+ more gear shift levers in the cab? so long that the install is clean and water tight.
Sam
cruiserdan said:I would also like to see a reduction gear for high range, instead of re-gearing the diffs.
locrwln1 said:Lower the high range, so you can keep the stock axle gears and put a 4 or so low range in the case, or manufacture a new one, and I think you would be set.
Jack
