copy of fj45 manual
Yep, a pdf file would of been great but I don't have a scanner. And even so most people usually perfer a hard copy for whatever reasons. And no I'm not making money at this. :) Hopefully someone out there who already has a copy and a scanner can post them. I sent out my last copy. So if there are folks out there I will gladly print more.
Actually there is one manual that needs to go to Cleanwater B. C. but I don't have access to my original manual......I'm still on the road. I hope I can get it done before I go to Cold Lake.
82-40 said:
Is this some thing that you need to print or can it be sent as an pdf file? If you are making a cuple of $$ thats cool I will send out a check but if it is only at your cost and if you can creat a pdf I can save you the trip to the printer and you can just e-mail it to me. What is better for you? Thanks, Brian
Ok fjwagon, I will see what turns up. If no one can set up a file of it then I will wait for others and when you print more then I will send you the money. I hope that you did not take me the wrong way, I did not know how you where working this and I did not want some thing for free if it was not meant to be. I hope that you are enjoying your travels. Brian
Do you have the ability and the desire to create a pdf file of it and send it over?
Put me in for one on the next printing or if anyone creates a PDF file.
FJWagon - are you back yet? Would still like to get a copy.
Thanks,
Brian
check the root45.com...there is a PDF file there. If not let me know. I may be able to make one for you. I may cost a little more if I do a single copy. It's cheaper if I can print 10 at a time. :)
Thanks,
Brian
FJWagon - I got it. Thanks!
Treeroot - great site!
Bump...Alive from the past.With all the old iron coming out there's got to be 9 more people that want one of these.
Rob
You can add one more to your cause 1fe pig. This might help me out with my project that I am working on.
