Coolant leak from thermostat to block bolts
Phoenix
I just replaced my water pump and thermostat among other things. I fired it up today to find coolant was leaking out of the driver's side lower thermostat housing bolt. Is this a common occurrence? What would the fix be? I did apply a small amount of FIPG to the threads prior to install. I think I ended up re torquing the bolts so it's possible that seal broke.
For sure it's from the bolt and not the housing or seeping out of the hose?
I usually give the fipg 24 hours to set before adding coolant. Might need to drain and redo.
