Complete paint job or just clear/topcoat (1 Viewer)
O-Town
I need help guys I'm wondering if I need to complete re-spray or if I can just clear coat over the top of this?
Earth
IMHO - If you clear coat, you'll just have really well protected messed up looking paint. That needs paint. How is the rest of the body?
O-Town
The rest of the body is good. The paint looks good except on hood and roof. Bit of rust on drivers rear quarter. It looks like the clear is just coming up and these locations. I would love to paint the whole thing but it's just not in the budget right now
Seattle
...or repair and repaint, for %80 of the looks and %40 of the money...
but, sadly, it never works to 're- clear' a base coat.... well... almost never...
t
In the membrane between heavy metal and gas
When did toyota switch to clear coat paints? I'm pretty sure my 85 doors not have a clear it's original and looks great but a little color comes off with each wax. Sorry for the paint ignorance just thought it is relating to this topic...
TRAIL TAILOR
Enabler
Supporting Vendor
Redding, Calabama
When did toyota switch to clear coat paints? I'm pretty sure my 85 doors not have a clear it's original and looks great but a little color comes off with each wax. Sorry for the paint ignorance just thought it is relating to this topic...[/QUOTE
D, I think the solid colors red, blue, tan, white were single stage paints and the metallics-- champage, gun metal grey/midnight blue, warm gray, copper brown and silver were BC/CC. I saw this recently posted up. Both my 10/85 8B4 codes were BC/CC OEM, this '87 Red was single stage..
The 4E8 champagne donor panels were BC/CC off a 87 and the Strong Blue panels off a 86 ( I think) were single stage.
J
TRAIL TAILOR
Enabler
Supporting Vendor
Redding, Calabama
J, A good shop could match the hood paint color pretty close, blend it, and shoot new clear. I personally would leave it until you could afford a complete paint job. I've seen the results of a touched up "AGED" BC/CC job gone wrong and it was money down the drain and pure disappointment for the owner.
J
bugsnbikes
Bay Area
I just did this to my girlfriends hood which looked a lot worse.
If you wet sand all the flakey clearcoat off w/400 grit wet paper and then shoot some matching paint to touch up on the unpainted areas.....you can clearcoat the whole hood and it will be fine. Wet sand the clear with 2000 grit after letting it dry a few days and then wax it and you'd be surprised with results. I used a good UV clearcoat from SEM which lays down fairly thick and I used about 1/2 can on touch up areas where paint was cooked and just came off when sanding off the dried clearcoat(whitish flakes).
The SEM clear and paint was $58.
I did the same to my lexus ls400 hood and and 80 series hood.
O-Town
Gosh you guys have a ton of good points. I really don't mind it for now but the rest of the body looks great. The hood is a sore thumb...
O-Town
Do you have any before and after pics?
