The Quick:
Are the male fittings threading into the slave & master clutch cyl. concave or convex?
The Long:
Clutch slave is leaking so time to replace slave and master cylinders. Am following the advice of kevinmrowland and am replacing my hard line with braided stainless brake line:
(-3an line) + (qty 2 swivel fittings) + (qty 2 10x1mm adaptor)
I've ordered the line and fittings...when the customer rep asked me a question: Convex or concave on the adaptor?
I guessed concave.
Might have to change the order.
I'm still limping by with the leaking slave...refilling the reservoir every chance I get...so I have not taken apart the old system to have a look myself. I figured that someone on MUD has seen these things themselves and might be able to save me the trouble of unhooking, re-bleeding, and continuing to drive with a leaky slave. (Thought: I probably can't bleed a leaking hydraulic system!)
So concave or convex? (I'm only assuming on how these definitions apply to a hydraulic fitting)
As always, THANK YOU!
The Long:
I guessed concave.
Might have to change the order.I'm still limping by with the leaking slave...refilling the reservoir every chance I get...so I have not taken apart the old system to have a look myself. I figured that someone on MUD has seen these things themselves and might be able to save me the trouble of unhooking, re-bleeding, and continuing to drive with a leaky slave. (Thought: I probably can't bleed a leaking hydraulic system!)
