I'm installing a new clutch master and slave cylinder on my 84 60. After accidentally breaking the hard line and getting some good advice on these forums, I have decided to skip the hard line/soft line route and run a stainless braided flex line in between the master and slave cylinder. I was wondering if anyone on here has done this, and if so, what type and size of fittings did you use to connect the line to the cylinders? What about compression fittings? Any particular size hose to use? Someone recommended a 5/16 inch flex line, does that sound right. I MUST get a FSM soon...Thanks
