Hi y'all.
I just fitted a new clutch kit (pressure plate, clutch plate, thrust bearing) to my 1983 HJ60 Landcruiser. Changed the clutch because of slipping - esp. in 2nd gear.
I also retro-fitted a vacuum servo unit to the clutch master cylinder - seems to work a-ok.
However, after adjusting the pedal height (181mm) and pedal freeplay (40mm) and clutch lever to slave cylinder pushrod freeplay (4mm), I now have much difficulty in moving the stick to reverse.
Any suggestions?
Any suggestions?
