Thanks bj40green I followed the your post 156 diagram,
1- P2 in fact is Pin2 which is oil sender. It gives 11volts reading.
Apologies if this is posted, but i could not find it my search. I am trying to couple the temperature sensor from an LT1 GM 5.7 liter to the stock set of gauges [stock for now] in a March 1979 land cruiser...looks like gene gauge cluster.
I think the resistance is out of range for the gauge. if I ground the temp gauge down....it reads and moves the dial, but when i hook it to the sensor out of the engine, it reads nothing.
I am suspecting the abc sensor is out of range for the gauge. see 188 ohms at operating temp, and much higher at cold.
best i can tell it takes about 30ohms to have the gauge at operating temp.
Could you please confirm the resistance range of the temp gauge?
Thanks in advance,
Eric
Further investigation reveals the fixed lug on right side is broken, which makes the worm gear a loose fit.Check for voltage on the top of the OIL sender. If 11V... sender is defective. If 0V, you have a wiring problem. If 5V but no reading on the gauge (after starting the engine) sender is defective.
That worm looks good to me. Maybe the counter runs "too heavy"' and needs a "taking apart & lubrication".
Rudi
Great thread!
I put a 2F in my 1970 40, and with stock cluster the temp gauge wont work. I have a sensor for the F motor but it seems too long to fit in the 2F. Anybody know if I can get adapter for the sensor, or I have to change the gauge to a later unit matching the 1978 2F sensor?
