Sorry...don't understand. Not just wanting to change the face plate, but to actually roll in miles.If the inside/outside kmh/miles range are the same you can just swap the face plate.
Open the cluster, pull the needle straight off, remove the 2 screws, change face plate....... ready.
Rudi
Found the issue and your photo of the fusable link was the key, when disconnecting the ammeter connection nothing worked, so a close look at the link and I only have one major cable shrouded not two so all the current was going via the ammeter circuit, I have removed the cluster s I wanted to find where the smoke was coming from and it was inside this cluster , I did a continuity test across the back of the terminal posts three where good but the ammeter was not , will check the output from the alternator later, as I now need to find a new fusable link.Wow, you have a nice problem here. On a '79 and later (with the 50-0-50 Ammeter) the Ammeter should NOT indicate what is going on due to a design error in the fusible link that acts as a shunt for the Ammeter (later more on this).
The fact that your Ammeter goes nuts means that "somebody" modified the wiring.
Let's start with your charge problem. First..... disconnect the Ammeter circuit by pulling the plug (connector) to the ammeter.
Find the fusible link (see picture) and disconnect the connector with the black and white/blue wires (bottom left).
Now you've disconnected the Ammeter in your cluster. I hope that your Ammeter is still alive (fingers crossed).
let's see if your alternator is doing it's job and post your problem in this thread: -► Voltage Regulator (ext.) / How it works
Once we have established that all is good with the charging we're going back to the Ammeter problem.
Rudi
Oooops, my bad, in that case change the speedo unit including the face plate.Sorry...don't understand. Not just wanting to change the face plate, but to actually roll in miles.
Fusible link repaired and all good, head lights dont increase with revs and charging is good , but no Ameter, fuel or temp working so whats the next steps to get them working, I did put on a new Voltage regulator ?The BIG question is...... why the 5Amp fuses didn't blow!!!!! That's exactly why they are there, to protect the meter and the wiring when the Fusible Link malfunctions. Another thing to check!!!!
Rudi
I have Aug. 1967 with both oil and amp meters
Can you post a picture?
Rudi
Ok strange no voltage on pin 3 , but let me tell you what works on the cluster High beam indicator light works, turn signal indicators work , whats your thoughts ?I think the wiring to, or the Ammeter self is fried/toast. This circuit is separate and has nothing to do with the other gauges.
The Fuel and Temp gauges are a set. Check voltage on pin 3 to cluster first.
The Temp gauge won't work if the Fuel gauge doesn't work.
Rudi
Plus here is a picture of the clusterOk strange no voltage on pin 3 , but let me tell you what works on the cluster High beam indicator light works, turn signal indicators work , whats your thoughts ?
I can't confirm if this is a time correct cluster because the EPC starts in 1969. In the years before Toyota used fiches which I don't have.
Nice cluster anyway.
Rudi
Thanks,
I am 100% sure this is the original cluster, i have a april -68 with same cluster aswell
