Driving in to work this morning in my 96 80 series. I live in NJ, so we got a mix of slush, snow, and freezing rain all over the roads. I get about 15 minutes in to the ride and I start to notice a vibration when turning the steering wheel. Mind you these are gentle bends on an interstate. The vibration is not there when going straight, but is there when turning in both directions.
I slow it down, swerve a little to feel what is going on. Turn off the radio. Can't hear anything due to road noise and the 80 being, well, an 80.
Get to work, check the front driveshaft and joints to see if there is any play. Nothing.
Start rocking the wheels, and nothing. I notice there is a stud on the drivers side front wheel that is sticking out a bit further than the others. I can spin it by hand. In fact, I can spin all of them by hand.
A big sense of relief that the wheel stayed on the truck, I was able to find the problem, and it appears to be the simplest thing that could of happened outside of ice and muck inside a wheel.
I have driven it about 300 miles since doing the wheel bearings, and properly torqued the wheel nuts to spec. Reading through some of the threads here, members are noting that they have never seen properly torqued wheel nuts come loose. I guess I am the anomaly, and it can happen.
I'll keep an eye on them for now, as I went around to the other 3 wheels and checked them and all of the lug nuts were tight. If this becomes an issue, I will swap the nuts out for a new set and see how that goes.
