Clicking noise on my 100
Discussion in '100-Series Cruisers' started by Jukelemon, Mar 1, 2004.
  1. Jukelemon
    Jukelemon
    2,396
    4
    Dec 29, 2003
    Louisville, KY
    A clicking noise has developed on my 99 100 which seems like it is coming from the inst. cluster or maybe higher/closer to the front window. It ONLY clicks between idle and 1700 rpms in any gear (Assumption. I used the 2nd gear take off to see). AND it will go away after about thirty minutes of driving i.e. drive to work and at idle you cannot hear it. It is significantly loud and reminds of the sound of old mechanical speedos when the gearing became stripped. No issues with any of the gauges.
    Any ideas?
    Thanks.
  2. xl715
    xl715
    128
    Dec 19, 2003
    I've seen on Hondas where a body seem will be missing a weld or rubbing with enough play to cause a ticking noise that is vibration induced, i.e. idle. Does pressing on any panels like the dash ect. change the noise at all?
    Just some ideas.
  3. Jukelemon
    Jukelemon
    2,396
    4
    Dec 29, 2003
    Louisville, KY
    Good thought but no, I have tried. It sounds internal for a lack of better words.
  4. T Y L E R
    T Y L E R
    2,597
    5
    Mar 27, 2003
    [glow=black,2,2]Maybe you could hone in on it , both in terms of location and nature by trying an old trick guys use to listen to engines .. a tube .. or dowel against the area .. other end against your ear . ???[/glow]
    [glow=black,2,2]T Y L E R
    [color=0000FF]T[/color][color=0008FF]O[/color][color=0010FF]Y[/color][color=0018FF]O[/color][color=0020FF]T[/color][color=0028FF]A [/color][color=0030FF]F[/color][color=0038FF]Z[/color][color=0040FF]J[/color][color=0048FF]8[/color][color=0050FF]0 [/color][color=0058FF]C[/color][color=0060FF]R[/color][color=0068FF]U[/color][color=0070FF]I[/color][color=0078FF]S[/color][color=0080FF]E[/color][color=0088FF]R[/color][color=0090FF]S [/color][color=0098FF]R[/color][color=00A0FF]O[/color][color=00A8FF]C[/color][color=00B0FF]K [/color][color=00B8FF]![/color][color=00C0FF]![/color][color=00C8FF]![/color][/glow]
  5. Jukelemon
    Jukelemon
    2,396
    4
    Dec 29, 2003
    Louisville, KY
    Tyler:
    Yeah, I need to do that. You cannot hear it from the engine bay.
    Any other 100 owner heard this?
  6. e9999
    e9999 You want to do what...? Moderator
    16,629
    513
    Sep 21, 2003
    US
    well, there was this rattle in a '99 I test drove. Seemed to be something loose in the pass airbag area.
    e
