Cig lighter no longer working....
Here's what keeps the metal socket in place.
See how the plastic tab is engaged in the socket:
You release the tab by rotating the socket a few degrees either way:
And this is the sequence for fully removing the socket:
1) Turn it a few degrees. 2) Pull it out a little. 3) Turn it back. 4) Pull it all the way out.
It's that easy!
Indeed, it is. Great write up.
Thanks.
What technique and instruments did you use to rotate and extract it?
I used a small screwdriver in between some of the slots in the back to help me twist it. It only has to twist a small bit.
Here’s a picture of all the components. The light socket is the first thing I twisted out.
