sleeoffroad
Supporting Vendor
What year 100's can you just "cut off the IFS crap" without starting to mess up more than say ABS? Do any of the other newer systems like atrac, etc get affected in a way you can't just "shut off"?
We chose to use a 80 rear diff, so we could not run the tie-rod behind that axle. So we ended up using our hi-steer arms that uses the ABS hole. I am looking to see if the knuckle can be machined it a different spot to re-insert the ABS Sensor. If so, then we just need to match the signal from the 80 birfield counter to the 100 counter.
Christo, that may be the best looking full size I've ever seen. Definitely will be a market as the older 100's get down in cost if a goal like 37's and streetable remains achievable.
Thanks, the truck is totally streetable. In fact we drove it back and forth to Moab and it is my daily driver now. Has a little shimmy at 50mph, but that is tires (confirmed yesterday when I had to put 31's on it for emmisions).
I think 4/5" of lift with 35/16" tires will be the ticket.
My wife needs a new car and I've been thinking she needs to test drive an older 100![]()
Go for it. You will not look back
!! Wife likes driving it too much anyway...she can have it!!
