What is the best carburator upgrade that isn't a Weber? I saw a rochester on a 1963 FJ and was thinking this has got be cheaper yet dependable. More importantly not the hunk of junk japanese carb on it.
The engine hesitates off the line I must reeve it up to get it moving. It appears too complicated for such a simple engine
The wires from the coolant senders to the carb were shorting so I repaired them hoping it might help the hesitation at start off and get my temp gage to work but without result. I also have replaced the voltage regulator and alternator but that was because both were worn out. I noticed the carb was in need of work but I have never seen so many moving parts for what is basically old school in-line 6 from GM. Now I am hearing removing the Japenese carb is not the answer???? I also have a new distributor electronic instead of points with a new coil. I plan to replace it next to see if the helps. The motor idles and runs great except when starting out coughs and hesitates. You are in Helena? Do you work on these old Crusiers?is this a US spec rig?
what have you done up to this point?
Thanks. I live in Great Falls. I am going to try and sort this out on my own. It is a retirement project that has been on my bucket list but it has been awhile since I have done any mechanicing. By the way the wire to the soleniod comes from what looks like a sensor attached to the head. It is a single wire. I bet when i get a timing light on it I find that to be at least part of the problem.there shouldn't be wires between the coolant sensor and carb?? coolant sensor should be a single wire, if there is a solenoid on the carb, I can't remember but I'm thinking it is a single wire also. but they should not be connected to each other.
Yes, I do work on Landcruisers on the side, as my schedule allows, and I am in Helena.
