Hey, you should not have to remove any of those items. Here is how I whould change the belts, I'm going from memory but I think its accurate.
First I would lossen the two bolts (14mm) that hold the power steering pump in place, just loosen them and the PSP should slide down to the one side.
Next remove the brace that holds the alternator to the air pump, one bolt and one nut, both 12mm. Then loosen the other bolt that holds the air pump (14mm on front). This should cause the pump to slid down. The main belt should be now loose enough so you can easily get a 12mm wrench in to remove the 4 nuts that hold the fan to the pully. Not sure if you need to do this but I found it easier to get to everything and it only takes a minute to remove the fan.
With the fan removed it is easy to get to the other belts. Loosen up the ac belt pully and it should easily come off. Sometimes the alternator belt can be a little tighter and harder to remove and install. To make it easier you might want to remove the alternator, this only takes a minute to do, just remove the one through bolt (14mm) and the two bolts that hold the alt to the tensioner plate. You will easily be able to remove and install the alt belt this way. It is a good idea to loosen the idler pulley at this time since there is notheng in the way.
I would install and properly tension the ac belt first since it goes in the back and the botton. Then position the other belts in place, and then reinstall the alt to its brackets. Install the fan to the pulley and retighten n the nuts. After the fan is back on and the belts are in place (still lose though), adjust the alt belt properly by using the alt adjustment bracket.
At this point you should have two out of the three belts tight (the ac belt and the alt belt). Now install the brace that holds the air pump in place between the alt. Next pull up on the PSP and retighten the bolts that hold the PSP in place. The only thin left to do is tighten the belt by adjusting the idler pulley.
