Finally had a chance to start on the water pump but have come into a couple of problems.
Got the fan shield off and the larger of the three belts off. Now how do I loosen the alternator (wrong it is the ??? under it ) on the right side of the engine (is it that one bolt on the back of it back by the engine block?).
How do get the smaller belt tension pulley loose on the left side of engine. Do I need to go under the truck or ???
Then what is next the pump or fan or....
Thanks, thanks, thanks in advance.
Pat
Pat
