Changing out the AHC suspension fluid?
I would've guessed pink would be the newer color as yellow is the color of most brake fluids. IIRC, the fluid I bought almost 4 years ago is yellowish.
I get my "large" syringes from a local large animal vets office.:D
Jokes aside :D Seriously, what IS the best way to get all the fluid out? I dont' want to put air into the system by doing it the wrong way. Just suck it out with a syringe, or ?
Thanks!!
Thanks!!
The best way to get the fluid out is to read post #6 in this thread.:banana:
The new fluid is Pink
thanks, yes I have read that post many times over. Now does anyone else have any advice on how to remove all the fluid from the resovoir; other than "remove fluid from resovoir?" as stated in post 6.
just curious if you have to remove the resovoir and dump out the old fluid or use a syringe or ? Ideas ? Don't want to suck air back in there .....:banana:
I used a 500ml oil syringe to suck out as much as I could which wasn't every last drop and then tipped the new in. It must have been said before but do keep an eye on the level before you re-start the truck!
Thanks!!
I'm not joking. Go by a large animal vet office and purchase a few of their large syringes. Go my Lowe's and get you a couple of feet of plastic tubing that will fit over the syringe and bingo! THese syringes will hold probably 1/2 cup. $3 a piece. I use over and over and over 'til the plunger starts sticking.
I just changed out the fluid in my '06 LC.
I suggest strongly that you get two cans of the AHC fluid, which you can buy online for about $30 plus shipping. My local quotes in the northeast from dealers were about $63 per can......if they happened to have it. It appears very few Toyota dealers have any. The parts guys seems mystified if you ask them about it.
The reason for two is that I followed the directions in post #6 and emptied the reservoir under the hood after setting the control to the "L" setting, allowing me to empty the largest amount from the reservoir before beginning the bleed process. (This made sense to me.....I can get the dirty fluid out more easily from the reservoir than by bleeding it through the system.)
I then dumped one of my cans of fluid in the reservoir, which nearly completely filled it to the top [far above the "max" line on the reservoir]. After bleeding the four actuators, but not the accumulator, the level in the reservoir was down to the bottom. The amount that you will bleed out by bottoming each shock absorber is very close to the amount in one can. Therefore you need two cans. One to replace the fluid bled out through the bleeders and another to replace the fluid you extracted from the reservoir before the bleeding. You wind up with about 1/2 can left over, but the nonresealable cap on the container probably means they don't want you to "save" it for future use. I assume it absorbs moisture like brake fluid, but I am not sure.
Obviously if you don't drain the reservoir before starting the bleed, you'll have enough fluid in just one can. Whats left in the system just won't be quite as clean.
I used 1 1/2 cans also I figured you only do ever 60K might as well make sure you get a good flush. AHC components are not cheap fluid is. I put my unused fluid in a empty water bottle for future use.
This is how we usually do it at work (no rocket science), just be careful you don't squish your melon!! One can of the ahc fluid is usually plenty.
1. Set the vehicle all the way to low (Reservoir full)
2. Remove all of the old fluid from reservoir. Fill with new clean fluid, I usually put the whole can in. 3. Start vehicle and let suspension equalize to "n" position.
4. Turn vehicle off.
5. Start at one of the back accumulators (doesn't matter which one) and using a hose on the bleeder, open very slowly and let weight of vehicle push fluid out. Close bleeder when vehicle is close to bottom.
THIS IS THE STEP YOU COULD GET SQUISHED IF YOU ARE NOT CAREFUL!!!
6. Start vehicle and repeat steps for each corner accumulator.
7. Usually one cycle at each corner is sufficient. If you are going to do it more than once you will need more than one can of fluid.
Cautions - don't crack bleeders while car is running. Vehicle will try to compensate for the leaking corner and you will have a big high pressure mess.
Fluid resembles very slippery brake fluid and is a PITA to clean up - so keep that in mind.
Also this is usually PM at 60,000 miles.
Questions let me know.
Hello,
I have Toyota Landcruiser 100, 4,7 V8, made 1998. (European version)
I found only one accumulator on my vehicle (on left side, in center of car).
Am I right or am I blind? :)
When I opened the bleeder, only few fluid went out (0,2 Litre). Then I had to start vehicle, set to LOW position and back to NORMAL position. Then I opened bleeder and again olny few fluid went out. (maybe it was due to lot of dust in fluid?) And vehicle did not comes to bottom.
So I repeated this several times and now it seems to be better, but not 100%
Do anyone has same experience?
Thanks.
Alf, Czech Republic, Europe.
Welcome to mud, Alf.
What you bled is the accumulator, and there is only one, according to T0yotas naming convention.
Here on mud (or should I say in the US?) it is common to call the spheres (aka gas springs) accumulators. So, what is described in the quoted step-by-step above is how to bleed the 4 spheres, or rather the AHC fluid through the actuators which the spheres are attached to.
To bleed the accumulator (as you have done) is also important as fluid runs in and out of it all the time. The accumulator acts as a small buffer for pressurized fluid, for those small on-the-fly adjustments of ahc pressure.
Hello,
thank you for informations ;)
I bled all accumulators (actuators) and changed the AHC fluid, but problem is not solved. Car is still moving up und down like there is no function of shock absorbers.
So it seems that problem can be in the spheres. Is there some test how to recognize which sphere is broken?
Thank you.
Alf.
... or is it possible to unmount the sphere and check if is OK or broken? Check the membrane by finger or screwdriver? (I dont know how it exactly looks like).
When I want to unmount the sphere, is it necessary to bleed all AHC fluid or bleed one corner is enough?
Thank you for answer.
Alf.
Thank you for link, but I did not find informations how to check the spheres :(
I found there only test how many marks on reservoir should be between low and high position of car. (I dont understand, why OK system should have 7 or more marks and why BROKEN system have less than 7 ? - please explain)
Thank you.
Thank you.
The Spheres are the gas springs.
When the car is in Normal height, the spheres and the normal springs (coils and TBs) share the load.
In Lo, the normal springs take nearly all the load, and the spheres nearly none.
In Hi, the spheres take a bigger part of the load.
Therefore, when the car is in position Hi, the gas springs (spheres) are more compressed, and there is more AHC fluid in the system, pressing against the membrane in the spheres.
The spheres slowly loose their gas pressure, so that after a few years there is not enough left to hold the weight of the car. As the gas pressure goes down, the membrane has to be stretched more and more, and in the end it will bottom out. When a sphere is new, the membrane moves easily, and has a long way to travel, and therefore there will be more AHC fluid flowing into it. When the gas is low, there will not be much room for more AHC fluid when the pressure goes up, so the difference in AHC level between Lo (=low ahc pres.) and Hi (high ahc pres.) will be smaller.
If you want the spheres to last, make sure you take care of your normal (steel) springs, because when they get weaker over the years, there will be more and more load on the spheres, and they will loose their gas sooner. That's the reason for checking the neutral pressure, and changing the rear coils when they get to weak, and tighten the front TBs.
As long as the AHC system is in order, and not leaking, there is no requirement to top up the fluid. If the fluid goes down, it means that more goes into the spheres, which means they are worn (out). The spheres are maintenance items, just like any other springs. They have to be changed every few years.
Thank you very much for perfect answer.
Now I understand :idea:
I have only 2 marks between Low and High position so it seems my spheres are "ready" to change :( .... my car is year 1998 and has 275.000 km.
Propably I have to buy a new spheres, because it does not make a sense to buy used spheres - they could be also with low pressure. New spheres are not cheap :(
Thanks again for your help :beer:
