Center differential lock indicator light blinking
Lansing, KS
Website
www.n0zb.com
2015 200-Series Land Cruiser
About 90,000 miles. Not my daily driver. I drive the vehicle one to two times a week for short distance/duration. I drive the vehicle in L4 for short distances twice a month. I have not regularly used the center differential lock.
Had the four-wheel drive serviced at the dealership last summer (no issues noted at the time). Vehicle serviced at the dealership ~3 months ago, nothing reported by the technicians.
For the past two months, on and off, then becoming more frequent, when I start the vehicle, the center diff lock indicator light will be blinking. After I drive for a short distance and turn the vehicle off and then back on the light is off.
I assume this is bad news? What actions should I be taking?
Thank you for your assistance!
Quite common, and thoroughly discussed on this board. You can try exercising the CDL frequently to knock out the cobwebs.. but yes usually once it's warm the error goes away.
The indicator light is more than likely just telling you the LC needs some off-road exercise and the differential needs some activation. Find a dirt road and run it in 4Lo for awhile. Take it through a few crawl modes. This should keep your indicator light off for a few months or more.
I also had this just before a battery failed completely. Perhaps the servo not getting the right voltage right after a start.
New X2 AGM and I’ve not had issue since. Could have been coincidence with having the battery pulled for 10 mins, clearing some computer stuff, but I doubt it.
Your battery is dying. I have two (2013 and 2014). Both have done this just before the battery crapped out. Both resolved as soon as I changed the battery.
Mine has done this many times and usually involves an overnight temperature change. I'm not sure about just exercising the widgets for it to go away - that hasn't been the case with mine as it sometimes happens on offroad trips when I'm using all the gizmos. And this has been going for at least two years - no battery issues. Check those links and there is a fix. I just haven't gotten to it yet. For now, I drive it around for five minutes, turn off and back on the vehicle and everything is good to go.
Hi All,
I have a 2015 LC200 and have had this issue multiple times. I have worked out the issue for me is due to the vehicle being parked on a slope, mostly with the car facing downhill.
Like others I would drive for a while to warm up, stop the car then restart with the issue gone. I have since found I don't need it warm, I just need it level. Multiple times now I have driven less than 100m to a level location, stopped the car and restarted with the issue gone.
Hope this helps.
