Thought I'd start my own thread as I continue to chase this. Started out here (
96 FZJ80 missing at Bad at 2800-3500 RPM full throttle) but now it seems I've got more work to do...
Swapped back in the stock MAF and drove truck around for 4 days in mixed driving with no issues. Started a 1300 mile trip yesterday and after about 2 hours of interstate driving with cruise set and loping along at ~70 mph, ~2200 rpms, had the CEL come on. Same old ones - 0325 & 0330 for 1 & 2 knock sensors. Re-set it repeatedly and it kept coming back on. Only "new" clue was when I would re-set it at a gas station stop, on the first re-start of the engine, the engine would rev and not find it's idle. I could kill it, and then restart it and it would behave normally. If I did not kill it, it would keep reving up and down between 2000 rpms and 1200 rpms, never finding its normal idle. It would then drive normally on the interstate but once I'd pull off, it would still not have a normal idle. Still same CEL's for knock sensors.
Both have been pulled, bench tested and reinstalled. Harness is new. Checked connections at MAF, but the harness side is new so everything looks great. It does behave like the MAF is wacky but not sure why this is setting off knock sensors codes. Engine is running very smooth, I went ahead and reset the ECU and put in some high octane fuel but the CEL's came on right away again.
Thought I'd try and clean the MAF with some spray cleaner for it. Maybe clean up the electricl connections. I don't have an EWD with me and really don't want to pull the glove box and crap to check the pins on the ECU.
Any other thoughts or ideas?
Thanks and
