Cel not on
Does it run?
Is it easy to check and remove the dash?
No light even on jumping wires
Thanks
Thanks for reply
Whats the best way to check those fusible links
Given your truck runs, I don't that is the issue. If the fuses were blown, probably wouldn't start. But to answer your question a good digital multi meter would be the tool to test the circuits for power and continuity.
Is using test lights the same connecting to diagnostic pins e1 to t1, would that give me a code reading
Thanks
Thanks for reply
for the cost your just better off replacing, i think i got a new set for about 12$. as stated above their probably fine but its possible to get corrosion in the wires that can be hidden by the wire insulation.
i dont know if using a test light would give the codes by flashing out, but it might
Thanks
Not likely. The diagnostic output is the flashing of the CHECK ENGINE light. Shorting TE1 to E1 enters the diagnostic mode on the ECU.
It wouldn't start or would start idle fine but die once you raised your RPMs, it's a bad bulb most likely
If FL1 was open there would be no power to the starter logic.
If FL2 was open there would be no power to the coil/igniter and injectors.
If FL MAIN was open there would be no power to the ECU.
