- Thread starter
- #121
I had a decision to make regarding the OBA. Go with a high pressure switch 120psi on/150psi off or use a lower pressure 85psi on/105psi off.
With the 85/105 - I can just run lines. The future ARB lockers will run at 85/105 whereas the 120/150 will require the use of a regulator to drop the pressure.
With a regulator, I would have to run at least two lines the length of the truck - compressor to tank (with regulator placed somewhere along that line), then regulator to both front and back of the truck to the couplers.
Without the regulator, one line runs from the compressor to the front coupler, to the tank and from the tank to the rear coupler. Sounds easier to me. Hmmmm......anyone want to buy a spare regulator?
In the end, I decided with 4 or 8 gallons of air in the tank, a compressor that is capable of producing 4 cfm @90 psi, I should be fine for airing up tires and using air tools. Plus, it simplifies the system.
I will end up using a very small in-line regulator for the air horns but that will be an easy matter to be addressed later.
The other problem I faced is that there are no NPT bulkhead fittings to be found on this island. And none of the stores knew what I was talking about. It looks like its time to get creative in the coupler mounting!
The other issue was where to mount the air/oil separator? And was it necessary since I did the oil modification to the compressor (blocking the small oil passage under the pulley with a 10/32 setscrew. My only option at the moment is to run the system without the filter as most sites I visit say that the oil passage screw solves the oil problem. Again, simplicity wins for me. I will look for a potential location for the oil separator and make it easy to add it if needed.
Today's job was to mount the couplers to the body and come up with a DIY bulkhead fitting.
First was to locate a 1/4 to 3/8 adapter and a 1/4 pipe to 3/8 hose 90° adapter. I could not get this to work with a straight through pipe/hose fitting so decided to put the 90° to work. I also happened to have a 1/4 pipe tap that came in useful.
Cut the hex portion off the adapter and file the cut end flat. Use the tap to enlarge the diameter until it can freely screw unto the 1/4 male pipe and you end up with this.
I tightened the threaded portion into the body of the pipe/hose adapter to get a good hold and obtain the gap I needed.
The next thing was to create a mount which was readily done from a piece of 1/8 x 1.5" flat steel. Bent, holes drilled and do a test fit. Looking good!
Finally, drill mounting holes and test fit to the front bumper. Looks good to me. The 90° adapter allows me to run the air hose without having to create sharp bends.
One down, time to build another for the rear. Then it is file and round the corners, paint and position everything. I will need to find some caps tomorrow to seal dust and water out of the coupling. Progress is slow but promising. More OBA adventures to come.
