castor correction
Looking at Slee's caster plates, it says they are suitable for a 4" lift.
I only have a 2" lift, but my caster is already -.5 so I do need castor correction. Does anyone know how much castor correction the slee plates give?
I called Slee but they are at Cruise Moab until May 9th.
you need caster correction bushings as mentioned above. 2" lift is too small to warrant the slee plates. i went through this issue a while back when i switched from j springs to ironman 2" springs. the plates clocked my axle too much and the 2" springs were curved to a point that there was contact with the bump stops. details in this thread help needed with Ironman 2" front spring install
good luck!
I seem to remember reading that the TJM rubber bushings are more pliable and therefore durable than the poly bushings in this application.
good luck!
Thank you
I find poly bushings never last. I will be going rubber, I was just hoping the slee plates wouldn't add too much + caster.
Also, I openly acknowledge my spelling is inconstant and usually terrible.
I think it may be worth getting the caster plates. I have the yellow OME bushings and they are inadequate--caster is near zero. This is for an 850/863 lift. One thing to consider (especially if you have 863's in the rear) is that the stinkbug stance also majorly negatively impacts your caster. I'm going to lower the rear end of my truck first and see what that does to my caster. If I don't like the results, then on go the plates. Haters gonna hate, but IMO, the more caster the better. You can potentially run into the same driveline issues that the 4" lift crowd does--and that's a risk I might be willing to take. Seems about half of them get away with no vibes.
You may also want to look into the offset trunion bearings they sell at slee--basically a lazy man's cut 'n turn. If I win the lotto, I'm plunking a 60 body on my LX450 :cool:
I'm just kicking myself because I just did the knuckles and bearings. The bearings seems like a great way to correct the caster.
Does your rig identify as a 60 or an 80?
:hhmm:
Don't you use the offset trunion bearings to adjust camber?
They can adjust caster or camber depending on how they're installed, but I see no reason to adjust camber unless you've bent your axle housing. I think the primary purpose is caster correction.
Is it really a 2" lift, or 2" 80-series springs? I wonder if the 60 series body is lighter and messing with the numbers?
