This may not apply to others - I bought an older (circa May 2019) Naviplus. It is a Lsailt multimedia video interface (model LLT-FT-VER7.1.5). It actually looks more like the EC Offroad ones people have posted than the new Naviplus boxes shown earlier in this thread.
I found that it works with Apple CarPlay including full use of all of the steering wheel controls (previous track, next track, volume up, volume down). Wired works great with the Autokit USB Adapter dongle it came with (CPC200-CMAP).
Some aha moments I had were that this setup essentially installs an android computer into your car. Within the Android OS, there are a set of applications, one of which is the one that runs CarPlay. In normal original equipment mode, it passes through the factory signal to the display - so it functions the same as any other factory infotainment unit. The cabling you install puts the Naviplus unit in the circuit between the factory harness and the head unit. This allows the Naviplus to capture a long press event from the Nav button to trigger and take over the display screen (leaving the head unit working in the background - so you can easily switch back and forth). There is an inexpensive dongle that gets installed inline on the USB line that tricks Android into supporting CarPlay (turns out people have used the same dongle to fool lots of Android devices into running CarPlay this way, from a $50 Fire Tablet to more expensive aftermarket head units). At the end of the day, all you really have is Android computer being tricked into running CarPlay.
The way Android gets configured is to pick up when you plug in your phone and by default, automatically launch CarPlay (AutoKit app running on the android). From there on out, you are interacting with the CarPlay user interface on the factory display. Once this is all configured, all you need to do is plug in your phone and CarPlay launches automatically.
Odds are you'll never have to deal with this, since you'll undoubtedly buy new. I got lucky and bought a used unit. This Naviplus was owned by a person who only ran Android - I'm an iPhone user so needed some additional tweaking before things worked the way I wanted. Initially CarPlay didn't work - it said the "box" was not supported and to contact the manufacturer. Naviplus support told me I'd need a newer "dongle" to solve this - the "box" that the software was complaining about was the dongle. What I figured out through experimentation was that the Android application to launch CarPlay needed to be updated. So, I downloaded an updated AppKit.apk file onto a flash drive, and plugged it into the USB port on the Naviplus. In Android, I browsed the file system until I located the USB drive and the apk file. I "clicked on" the apk file and it installed it - I followed the prompts, and then, like magic, the software recognized the dongle, and CarPlay loaded. I'd never used Android, so I learned a lot!
A couple of things I've learned in my 24 hours with this is that in order for the audio to work from the Naviplus:
1) You have to remove your phone's Bluetooth pairing with the factory head unit
2) You need to have the audio input set to Aux
If these conditions are not met, you won't hear any sound, even though the CarPlay interface thinks it is playing sound.
Oh, and for those of you that want more than Apple CarPlay or the Android Auto, there is a whole Android computer that can run any compatible application, play music, show videos, browse pictures, browse the internet, etc. I have no interest in all that, I just wanted CarPlay, so the Naviplus functionality is mostly wasted on me.
One more comment: you can also screen mirror using the EasyConnect app on your iPhone phone and the Android unit. The resolution is iffy, but it works.
