Rhinoliner
I'm about to start pulling my hair out here and I need some help!
The engine starts perfect and runs perfect until it warms up (temp guage just past first bar). After that, it will continue to idle perfect as long as you let it, but if you rev it up to about 2K to 2.5K RPM the fuel level in the carb will quickly decrease until the engine dies.
Some background info:
1978 FJ45 with a 2F from Canada (no emissions stuff ever as far as I can tell)
Compression: 130, 130, 132, 132, 135, 137
Cam and lifters: brand new and valves adjusted properly (Hot)
Carburetor rebuilt by me using the Toyota manual and soaked in a Chem-Dip bucket overnight. (looks like new) Keyster? carburetor kit
Float level triple checked. Fuel at half glass at idle
Power valve jet .060 - plunger operates smoothly
Main jets (150 & 220) and (141 & 180 current) I've tried both sets and still have the same problem
Solenoid valve operates properly
Choke breaker operates properly
Only 2 vacuum lines on carb, choke breaker and distributor. Both checked and fine.
Intake manifold brake booster port capped and still the same problem.
Intake and exhaust manifold machined together and new Remflex gasket installed
New fuel pump. Same problem with original fuel pump.
Fuel tank professionally cleaned and lined. Fuel lines and filter are new
Intake manifold checked for cracks and none seen
Original exhaust flapper installed and operates freely
I've sprayed carburetor cleaner all over intake and carb while idling (warmed up) and there is no change in RPM
Does anyone have any ideas of what I am overlooking? This thing is killing me.
