Hi Gang, I'm new here and could really use your help. Purchased an untouched 1976 fj40. Only work done by po was holly carb installed and new header. Po gave me original Aisin carb which I had rebuilt and installed. All vacuum hoses hooked up correctly. This is the thing. Only runs with choke engaged. Idle actuator has 10.2 volts and clicks when ignition is turned on. Have 6.3 volts at other electrical connection in front. By the way, truck ran well with holly except for accelerator pump issue. Any help would be appreciated.
