- Thread starter
- #61
Colonel,If your fan draws less than three amp your configuration should be reliable. I will measure the operating current for the cooling fan tomorrow and let you know what it draws. If you look at the SPAL application notes, it does show the thermal switch as a low current input to their controller and the higher current for the fan motor is a separate output, similar to the VCM controller that you are using. Also the spec sheet for the VCM describes the 87 and 87a as 'a logical exclusive OR' (I would assume that there are pull-ups inside). Just saying.
I appreciate you taking your time to find the amperage that a carb fan draws. If it is much more than 3 amps, I'll remove and install my Klixon 1NT switch. The Klixon is rated for up to 25 amps, thus shouldn't be an issue. However, this sensor is a 150 degree on and 135 degree off. I would probably find another location to install it in lieu of attached to my exhaust manifold, as I have the SPAL currently installed.
As far as my wiring of the Waytek (In-Power) relay as I have it installed and being no electrical engineer, I took the directions & wiring diagram from a phone call I had with In-Power's technical department. That is the reason I used the diode and knowing where & how to install it. That phone conversation was more technical than an Good Ole County Boy from GA cared to know about relays.
(.....pull ups inside)? Too technical for me, went right over my head.
