Here is mine, looks like fed spec
Get a Klixon 1NT Fan thermostat that closes at 160F and opens at 140 F. Put a relay in line with the thermal switch and fan to interrupt the current when the ignition switch is on. Mount the thermal switch near the base of the carb.
Coolerman,Thanks for the info on the diode.
I think this might make a good "kit" for those that do not have the OEM Cooling Fan Timer Module or have it and it doesn't work. If I can find a source for the matching female OEM timer module connector, it would be easy to make a plug and play kit assuming they had the temp sensor already and it actually works... Lot of if's in that statement!Of course a replacement sensor could be gotten... Something for me to ponder on...
Colonel,GA - I am curious why didn't you use the 12 volt logic inputs?
Looks great! I see they did include the correct terminals. That is exactly what I would have done with the diode also. Fold a piece of tape over the exposed diode when you mount it to prevent shorting it out accidently. I have had no luck sourcing the odd connector for the fan module or its mating harness connector.Coolerman,
I finally put together the adapter that will plug into the Waytek 20 min relay I'm using for my Carb Fan. Using the Waytek #31073 Terminal for Relay Connectors, they just clipped into the adapter very easily. Here is what it looks like.
Yeah, I'm between jobs at my day job for a while so I can surf MUD a lot more often!This is a great thread. I'm no help at all but I am glad to see this because I tried to get my fan working on my 60 and was totally stymied. Never realized there was a fuse under the wrapping. Thanks guys.
Also, glad to see you have some free time on your hands, @Coolerman. Welcome back.
Colonel,The logic inputs are pins 87a and 87 and are low current inputs that are meant to interface to your thermo sensor or a manual switch to manually turn the fan on/off, if desired. A concern I have about your configuration is the maximum current spec for the SPAL switch. The SPAL specs are: Max. Current & Voltage: 3 amp, 32VDC, grounded case only (https://webstore.spalusa.com/en-us/...es/185-ts/temperature-switch-185-degrees.aspx). Not sure but I think the cooling fan may approach that current level, or even exceed it. Who gave you this design?
My truck is a Ca. one-purchased in Sept '77 by my wife's sister. it came with a large wiring diagram(but for some reason the diag says 78 on it) . The truck was desmogged years ago, but the cooling fan connectors are still there.--up front-driver's side - light green connector. The cooling fan relay is located under the psngr side fresh air duct , on the firewall(as well as the wrapped 5 amp fuse Mr. Toyoda put in). Was not able to get the relay to work, so I installed a scavenged bilge blower from a Searay boat and mounted it as close to the orig as I could.--works great(has a scavenged mechanical toaster over timer to make it run)!myquestoyota: Do you know if your truck is a California emissions spec truck? Reason I ask is all the 77 schematics I have and the actual 77 harness I have do not show the Carb Cooling Fan System. That must mean the cooling fan was only on California spec trucks.
So... I need a 1977 schematic for a California Emissions spec truck! Do you, (or anyone else reading this thread) have a 1977 FJ40 California spec schematic? Maybe this is in the Emissions manual for the 2F?
