can't find these turn signals...HELP
I need some help folks. I posted in the wanted section and got no response so I'm going another route. I need a set of front turn signals for my '63 fj40. I am looking for the older style round ones that mount on the fenders. Does anyone know if any company still carries these. I need the whole assembly and have no luck turning these up. I've exhausted all other possibilites so now I turn to you guys for help. Any information in tracking these down would be appreciated.
Thanks
Did you get it figured out yet?
can get em new from the dealer, I think around $20, can also get new bib lights, the lens is like $6 the whole housing with lens and gasket is $12, lens are amber not clear like originals.
and if you don't like the way the stock lights work, ie....headlights and no bib lights(this is the correct OEM set up), you can run a jumper wire on the back of the headlight switch so that the bib(parking) lights and headlights are on at the same time, I did this to my fj45, I much prefer it.
You can always try cruiserparts.net. They would be used, but good prices and James seems to know his stuff.
I have two off my '68 that are in good shape except that they
are painted black (not the dark gray metallic from the factory).
Say $25 for two. The new ones are readily available for about
$24 per light, just so you know.
