No need to take the UCA out first. That's the beauty of that little clamp-press.The uppper ball joints are kind of a pain to press in and out, but the job is possible with a little heat and a harbor freight press
Man, I tried and tried to do it in the wheel well, but I could not get the press to fit properly with the knuckle and axle shaft still in position. Which was kind of a blessing since the ball joint had a hard time going in straight and needed some persuasion to fit squarely. Really, with the tire removed the upper control arm only takes about 10 minutes to remove.No need to take the UCA out first. That's the beauty of that little clamp-press.
Bumping a slightly old thread. My 235k mike cruiser needs some service with the front suspension system. There are some good recommendations here and I’m learning from them. Basically, it i can gather a list of items to replace from this thread, and OEM seems to be what is recommended if the suspension will remain stock, ie not lifted. Is there a better comprehensive thread? I could not find one while searching via google. Also, is there a good resource to lists and shows all the parts and their role in an IFS? Thanks!
Ok thanks, that is what I thought you meant but wanted to make sure. None of the cups were small enough to fit the top side of the ball joint to press it down with another appropriately sized cup underneath (like above). Makes sense.Just like walking, we step with left foot than right. In kit I used, which is same as pictured above. The kit doesn't have a cup that fit UCA ball joint in place. So use the screw end of tool bare. Place bare end on bottom of one side (say left) of ball joint. Crank CW tool screw end bare, with cup on top side to press ball joint into. Then move bare tool screw part to other side (say right) of ball joint. keep moving from left to right, walking out ball joint, a little at a time.
Basically the tool be set up the same as seen above, which is pressing in a new ball joint. Only to remove, it is without the large long cup on bottom (bare).
This is what I did as well. Made a huge difference. 2nd side went a lot faster than first after figuring out all the tricks. Nice to save the money but man was this job a pain. Felt real good when it was done tho.After a big fight getting my LBJ to release the knuckle I was short on patience for another problem.
Tried the walking out method a few times without success.
Pulled out my angle grinder and took off the stem of the UBJ.
Once that was out of the way, I could easily use my desired fitting ( HF Maddox press kit )
1 minute of grinding and another 3 minutes pressing it out.
View attachment 2272565View attachment 2272566
No, they are completely different.Are the upper and lower ball joints identical part numbers? Some are listed just as front whereas others are lower/upper specific.
Toyota doesn’t sell the ball joints separately. You’ll have to get the whole arm assembly.Actual part numbers and links to source said part numbers as well as the bushings would be greatly appreciated.
You can buy just the ball joints. Maybe not from Toyota directly but you can buy them. It's been 2 years since I did mine so I can't recall where I got mine from.Toyota doesn’t sell the ball joints separately. You’ll have to get the whole arm assembly.
Hopefully this helps. It’s a 4 pc kit I bought from @cruiseroutfitToyota doesn’t sell the ball joints separately. You’ll have to get the whole arm assembly.
