because i had 2 do this same thing after 4 months, and trickle charging sucks, not worth my 200 bones
i just got a cheapo from autozone, never had a prob
OK, saw this thread and had to jump in. Accidentally cored my perfectly good brand new Duralast Gold battery mistaking it for a dead yellow Optima. So, my goal is to save the Optima so I didn't completely screw the pooch by using my perfectly good battery for a core...
Connected my mutli-meter in and it was sitting at 11.88. Put it on a 2a trickle charge for 2 hours, now it is at 6a for a while, and before bed I will switch it back to the 2a. Hopefully over time it will make its way back up.
Where should it be to show I am back in business? Around 14? I have read all the way from 12.6 to 14.4 so I am not sure... Anyone?
Jonny
Jonny
Kinda a general response here;
A) Used Top-grade sears batteries for years to get the most CCA's & the best warranty. Ended up executing the warrantys for most of them, even though no winches, heavy duty lights, plow or mega-stereos. This was on a series of CJ-5's & CJ-7's, being used for both - daily drivers and med-level off-roading.
B) About a year after Optima came out, the reviews were still good, so, got my first yellow-top. Forget which series, just know that it was the highest CCA & I could make it fit. That was .... 12(?) years ago.
I travel a lot on extended business NOW, and sometimes, my 75 FJ40 doesn't get driven for ... a L-O-N-G time. When I'm home, though, I will use it for a daily driver (so, a lot of starts). The stereo has a habit of sucking it low (to dead) when I'm gone a long time. I've had it so dead that the stereo was dead, no glimmer from lights, etc - DEAD. (Yeah, I finally put a cut-off switch in there). Yet still been able to charge it back to life, and, with some daily driving, it got back to normal within a week. I've load tested it 3 ways (sears home load tester, battery shop, and my mechanic's pro-shop load tester) and it still is showing upper-90% (avg of 3) of original rating.
On the other hand, I put a dual battery (Yellow-top optimas) system into my OTHER vehicle (yeahhhh ... a CJ7), but, between my travels and the build-up, the first yellow-top that I got for it, ended up sitting for much of 4 years, and then suddenly, it wouldn't hold a charge - had to go to the (newer), back-up battery for starts, and boy, did it make the alternator scream when I threw the switch back. The back-up was bought 4 years later, when I put the dual system in. I replaced the bad one, and have it sitting in the garage. But - bringing it into service, then topping it off, letting it die DEAD (this time from stereo AND analog clock) for extended periods, then topping it off again for short periods (repeat, repeat) - there's no expectation of ANY battery surviving THAT.
NOT a problem since.
My point is, I guess, that my experience with yellow-top optimas has been pretty good, considering. And, although I haven't used sears in a long time, they were good for about 2/3's their warranteed life, and, that their warrantees were expensive to execute. I'm going to try the "bring 'em back to life" things listed previously here on the dead one, and see if it'll work (then, wonder what to do with it...maybe just keep it on trickle ...).
That said, I saw that one person mentioned a "Desulfanator". Others mentioned that batteries have a limitted number of cycles in them.
I've been reading up on desulfanators for a few years, and, they come in 2 .... "flavors". One is built into a trickle-charger (tender) that you plug into your garage wall while parking the vehicle; the other, you wire into your system permanently. This desulfantor actually does it's thing (I think) even while the vehicle is operating. Essentially, the desulfanator pumps reverse current micro-bursts back through your battery (periodically) to reverse the chemical process that occurs in the battery. This not only actually "refreshes" the chemistry, but breaks down the sulfer that starts plating the floor & cells of the battery internals. (Think, "breaks down the plaque in the arteries of your battery"). Sulfer plating on the battery floor that manages to finally reach the sulfer growing on the cell plates (think: "Stalagtites growing and meeting stalagmites") will short a cell out, reducing the battery's total Voltage capacity by that much (Typical auto battery = 6 cells x 2V potential, so - 1 cell shorted = a drop of 2 volts).
There are claims (including purportedly by fleet operators) of being so happy with perfaormance after installing desulfanators into part of their fleet for testing, that they even pulled long-dead (1 or more cells shorted) batteries out of the service-dept junk piles, hooking them on the desulfanator / trickle charger, and resurrecting them to the point of putting them back into fleet service. I have yet to find anything about it (desulfanator) being "not worth it", "useless", etc. Whether anyone feels that it's worth it to potentially have their battery run 2x, 3x, 4x its normal lifetime for them (as opposed to cost / effort to purchase and install in their vehicle) is an individual choice.
Just my $0.02. Suggest that people do their own research before spending $$.
Very helpful.Jonny, I would be very interested in your results...may help guide me.
As to your queston re: your batt., anything above 12.5 & you are good.
Let us know if you get yours back up/running.
Good luck, John
And USMC, very interesting post...thanks
Well guys, I have been doing a mixture of trickle charge at 2a and regular charge at 6a for several days now. The battery started at 11.19 as per my picture above, and right now I have it up to 12.55. I don't have my 40 here otherwise I would run it and try and get a complete charge on it. I will keep doing my charging for another couple of days and hopefully this battery will be fully back from the dead
Jonny
Using my batt. as a guide, your real test will be after you take it off the charger for a day. Mine would be at 12.80 or so when first taken off the charger, but overnight it would always fall back to 11.88. Same pattern/results 3 or 4 times. Good luck.
John
Thanks Jim, my battery may be too far gone but from the info I've gathered (mostly from the good folks here) my recovery plan is as follows :
1) buy a C Tek 800 battery charger, remove battery from truck & charge until it can hold 12.5 or above.
This may take a day, or many days. If it won't get there I'll dump it & get a new battery.
I live in the sticks & a C Tek type or similar charger is not avaliable locally. I will be going to So. Cal. late next week & will purchase the charger & begin the process next weekend.
I've decided on the C Tek, it's one of 3 that Optima 'unofficially' recommended & I've fallen for the hype on their ads I've seen over the years. I currently have 4 Yellow Tops, so I have convinced myself I need one of these anyway. Will report the results of the recovery attempt.
John
