I have been installing a alarm/keyless/remote starter (Viper 5701), I have successfully got all the alarm portion installed, now I have to wire in the heavy gauge starter wiring. This involves tapping in to the starter switch wiring. I want to create my own "T-harness" that will plug in to the switch harness then into the cowl harness, I will splice into this harness with my remote start wires. This would allow me to solder and heat shrink all connections on a bench outside of the car, then simply plug in the "T harness" into the OEM connectors.
I know I can buy the cowl harness ($3k) and ignition switch ($100) and harvest these connectors, but is there somewhere that I can buy just the connectors? Are these connectors proprietary, or is there another source to get ones that would fit?
I really do not relish trying to solder and heat shrink, under the dash, where there is virtually no slack in the wiring harness. I want to avoid the "T-tap" type connectors, as all the install recommendations I have read, say to avoid them for the heavy gauge starter wiring.
Good news is, I will hopefully have a writeup, at least on the alarm/keyless entry install, that uses the Toyota alarm/keyless wiring harness, so you can wire up the aftermarket alarm harness and OEM connector, outside the vehicle, then just plug in, except for the siren wiring, and hood pin switch.
Looks like prices are about 20% off MSRP, hopefully cdan can come through a little cheaper, or I may have to try to get them from a junkyard.
