Can anyone verify wire colors/plug end colors for an 87 4 runner 22re?
dohcdelsol93
snoogans
Greenville, SC
I had to do a wiring swap from one 87 4 runner to another. One was automatic. The automatic looks like someone had already pulled the harnesses and swapped it with another. It had a tach.
The harness I'm using is a 5 speed, no tach. Both have ac.
I need the wire colors and plastic plug color for the following of any of you could be so kind.
Stater solenoid (to key)
Oil dummy light sensor
Water temp sensor
Brake fluid reservoir sensor
Im ditching the 22re for a diesel so all other wires for engine harness shall be removed.
Sadly Both harnesses have been hacked a bit but one is much better than the other.
Ih8mud to the rescue. Thank you.
Connector color.
Stater solenoid (to key): Brown, one wire, on the engine harness
Oil dummy light sensor: white, two wire, on the engine harness
Water temp sensor: Blue, one wire, on the engine harness
Brake fluid reservoir sensor: I want to say yellow, two wire, on the dash harness
Can I add a plug color and wire color to the list guys? The ac compressor power wire. Thank you guys ahead of time.
Blue/ black single spade hanging out on the inner fender by the battery
What he said.
Thank you! I thought that was the one.
