- Joined
- Apr 14, 2004
- Threads
- 1,468
- Messages
- 36,688
- Location
- 818-953-9230
- Website
- www.marksoffroad.net
1. Excessively worn gears will cause the gear oil to overheat and come out the breather. Adding a hose to the breather only addresses a symptom, not a problem.
2. If it's been some time since an overhaul was done, the chances of #1 being true increase.
3. 76-78 cases are the most at-risk cases for cracks on the rear of the case around the idler shaft. If there is any moisture in the ribbed area between the shaft and the cone cover for the trans tailshaft, you should give that a good cleaning and further inspection.
4. If you need a dual seal speedo housing, I sell them too.
Best
Mark
Best
Mark
