Wondering if I can use my tree saver to spread the load between 2 recovery points on my bumper.
Thoughts?
Thoughts?
The angle formed between the two lines should not exceed 120 degrees (see attached). There probably isn't a huge argument for not using the tree strap per the OP's question assuming the strap is in good condition and rated for the task.
However a "basket" type sling arrangement would be more typical for this type of usage or two individual straps.
I'd use a suitably sized and rated D-type shackle with the bow portion interfacing with the sling/sling loop ends.
As I've suggested countless times: For about $20 everyone should buy, read and understand Jerry Klinke's "Rigging Handbook" (now in its 4th edition). A worthy investment for everyone's safety.
http://www.amazon.com/Rigging-Handbook-Edition-Jerry-Klinke/dp/1888724161/?tag=ihco-20
A basket hitch would be fine. You NEVER thread any sling, steel or synthetic through the attachment point. NEVER NEVER NEVER.
A basket hitch would entail one sling with the two eyes each attached to the anchor points of the vehicle and the recovery line attached onto the middle of the sling.
A "bridle" is two slings attached at one end with a ring or shackle. Basically the same as the basket, but there are two slings attached at one end forming a third attachment point.
Ok...I don't see the inherit problem with using a suitably rated and rigged sling as a choker or basket sling in a static type recovery event between two rigs and/or 1-anchor and a rig where the connected points are: Between the recovery line and two frame or bumper mounted rated recovery anchor points on the recovery vehicle (assumes <30 degree included rigging angle and suitable attachment rings at the bumper side). The need for this type of rigging assumes the forces are great enough to warrant spreading the load to more than one anchor point. In reality, based upon most if not all the recovery situations I've been involved in this extra step, if you will, is not warranted. So this question is more theoretical...
The advantage would be spreading the load between two anchor points of the frame...which seems to be a good approach rather than isolating the stress at one frame anchor point. And maintaining equal tension on each leg of the hitch along with maintaing a consistent included angle at the winch side.
^, like most recovery situations, this isn't a universal panacea but yet another tool in your recovery tool box if the need arises.
Note: I'm not 'arguing'...just trying to better understand.
Agreed: Measuring the included angle (keep to <30 degrees) might be simpler and potentially more accurate than measuring the wider angle created between the bumper and the recovery line when a sling is utilized. Either way: Its the same angle measured at a different reference point.
This is also a good link to bookmark: http://www.pirate4x4.com/tech/billavista/Recovery/index.html
