Can the camshaft be replaced without totally disassembling the engine? It is currently on an engine stand.Definitely need a new one.. and yes C-Clip hold it...
Yes.. if you not replacing cam bearing.. what is usually recommended..Can the camshaft be replaced without totally disassembling the engine? It is currently on an engine stand.
Bummer. I just put the oil pan and side covers on with new gaskets. I might have to find an engine builder who can help me. This is above my pay grade.Yes. Distributor, rocker assembly, pushrods,sidecover, lifters, crankpulley, front cover, and your ready to pull the cam out of the block
Well... it can be done with pan and side coversBummer. I just put the oil pan and side covers on with new gaskets. I might have to find an engine builder who can help me. This is above my pay grade.
If flip the engine and hold the pushrods .. it will work without removing the liftersOil pan can stay on. Side cover needs to come off to remove the lifters.
Ok. I will order the Melling MC803 camshaft. Is this an exact replacement?I agree (having removed my camshaft to replace the front plate gasket) Oil pan doesn't need to be removed. The side cover is a lot less involved, of course. You have to get to the lifters to remove them before the cam can be removed.
From your avatar, it appears you may have an F engine. If so, be careful to get a camshaft with the correct drilling in the cam bearing. F engine cams were drilled on number two and 2F ones are drilled on number three.
Look for the Melling MC803 camshaft for LC's. Their picture show drillings in both the 2nd and 3rd bearing. $260 - $300 if you're lucky.
Wow. Upside down? I guess it could be done but if I was putting in a new cam, I’d want to pull the lifters anyway and have them checked and/or resurfaced. Have you pulled a cam out like this?If flip the engine and hold the pushrods .. it will work without removing the lifters
You’ll need a new timing cover gasket. If it’s old, a new valve cover gasket. Maybe a new distributor o-ring.Ok. I will order the Melling MC803 camshaft. Is this an exact replacement?
Amazon product ASIN B000C4POMI
Is there anything else I might need other than a new side cover gasket and C-Clip for the gear?
As well as a timing cover gasket, you'll need a timing plate gasket. I'd get a new timing cover seal as well. Items # 25, 27 & 29 "HERE"Is there anything else I might need other than a new side cover gasket and C-Clip for the gear?
No I did't .. it's just a theory..Wow. Upside down? I guess it could be done but if I was putting in a new cam, I’d want to pull the lifters anyway and have them checked and/or resurfaced. Have you pulled a cam out like this?
