C1268 2000 Landcruiser
Southern Missouri
Hey guys and gals, I’ve searched and had no luck. Everything pops up for the 200 series rigs.
driving my new to me land cruiser a couple weeks ago and I realized it has an Overdrive off button on the shifter. So I pushed said button, harsh down shift and then Christmas trees on the dash.
vsc, abs, all that fun stuff. So I clear the codes when I get to the family shop and go on. Noticing it hunts for gears especially in overdrive, in and out in and out. Only way to make it semi right is turn the overdrive off.
today I drive it it again and pull codes since I don’t have my own personal scanner.
the codes that pull are
C1223 abs fault
C1268 transfer L4 position switch circuit
no engine or trans codes.
I’ve found this flow chart, https://lc100e.github.io/manual/rm/rm970e/m_di_0294.pdf
Also should mention I was a tech for 15 years, I’ve just not got access to what I used to. But I’ve still got a multimeter and hope to get a better diagram.
input?
Thanks!
I guess I never updated this.
Mine was hard to shift between high and low range due to the shifter linkage being stuck. I removed linkage and cleaned.
I also never had this problem after, pretty sure the transfer case wasn’t completely in gear when it was having the problem.
Any information on this, for fix? Having same issue
The FSM/EWD for your 100 series is in the Resources section. I'd start there.
Try cycling thru H-N-L on the tcase a few times (while stopped). This sensor is just a mechanical detent ball that gets pressed in (closes the circuit) when the tcase is shifted into low. (there's one for neutral too.)
Tcase could not be fully engaged in high, ball in sensor could be stuck, or wiring/electrical plug issue. Start with easy stuff.
Was there any fix for this? I'm going through it now.
I think I fixed it with freeing up the H-L shifting. I honestly don’t even remember creating this thread 😵‍💫
But I do remember pulling my shifter mechanism. Getting it hot with a torch, freeing it up, lubing it and being amazed how easy it was to shift between high and low.
100 series, like to have ALL switches, buttons, shifters, etc. used. When we don't use them, for long periods. Stuff freezes up. Often, by exercising them repeatedly over time, they come back. Other times, we need to service. One we see a lot, is CDL light stop working. We then may have CDL engage, without (no light) realizing it. If while turning sharp while backing, you feel a binding in road. CDL is on. Other times T-case shifters freeze up. These are just some of none use issues we see with age.
