Buying/Selling/Trading thread (1 Viewer)
A friend of mine is selling his 1978 FJ40. Posting up here before it gets cleaned, detailed, re photographed and put up for sale nationally.
2F, 4spd, A/C, disc brakes (4 wheel), Old Man Emu 2.5” springs and suspension, Pakistani soft top with matching doors.
84K original miles, original paint, original upholstery, no rips or tears. Less than 1500 miles on BFG Mud Terrains.
A couple of minor rust spots, some minor chips and scratches. No dents. Never has had any body repairs, undercoating, detailing or touch up done. Frame and underneath is rust free and solid. Aside from some aftermarket additions, This is probably the most unmolested and untouched FJ40 around anymore.
This vehicle is turn key. Runs and drives well. Never been off road. Never parked outside. Always been in garage or under carport.
Non stock items are Weber carb and radiator.
Original hard top, side doors and ambulance doors are in good condition and go with vehicle. Original carburetor and air cleaner also.
$31.5K
Please PM me for contact, more pictures and info.
$29K
85-87 H42 4-speed
Free pickup at my shop. Pulled for H55f swap. Must go soon.
selling a set of five OEM 16" split rims. Asking $500 but I'd like them gone quick so make an offer. And no, no tire shop is going to mount tires on these for you.
Copied from my listing in the classifieds:
Complete drum to drum late-model FJ40 rear axle in good shape. These don't come up often anymore. Not sure what the diff ratio is, I will pop the cover off and look.
$1K without a third member, $1100 with the third member if it's 3.70, $1200 if it's 4.11.
I'm also able to completely rebuild this axle with all new brake parts, inspect/rebuild the diff and install the locker of your choice for a drop-in upgrade if desired.
Located in Orlando
As long as the rim/ring isn't rusted, I think a shop that does tractor tires or tractor trailer tires has the safety cage to take care of them. Or if you are adventuresome, run a chain through the hub hole around everything a couple times. But me, I don't want to die, so I'd let the right shop do it. But no, no normal tire shop will touch them.
Free pickup in Orlando. 71 F, 3-speed transmission/transfer, and complete column shift setup. Everything has been sitting for about 25 years.
I just need to keep the carb and flywheel.
I have a set of Tundra wheels with 4 MT tires + 1 AT spare + 1 Steelie Spare for a total of 6 wheels and tires for a 100 or Tundra or Sequioa just sitting in my garage. $300 takes all 6. Pick up in Weston FL.
Dobinsons bumper up for grabs..$700 takes it…west of orlando
bumper is sold…thanks to all
Looking for a 4-speed FJ40 2F bellhousing and 80-84 split-case shifter setup.
Anyone got a good FJ60 gas tank before i plunk down $750 for a new one? (Carb version)
Have a welded up summit cruisers tire carrier and corresponding oem bumper wings available for $300
Also have some slee caster plates for 3” lift $60 and some rear slee sway bar drops $30
would prefer local sale
Wtb 80 series steering box. Space coast, Orlando, or Tampa pick up. I can pay shipping if located in a different area.
Box doesn't need to be in pristine condition, I want a spare to rebuild.
Where in Florida?
