Just a couple of things I would suggest: One, Toyota does not back up the dealership 100%- I can promise you that is a fact. At my dealership, thousands of dollars a month are written off in unpaid warranty claims where we performed a repair in the interest of good will for the customer and the factory denied payment. That is money we lost.Update here! Busted diff repaired under warranty!
The fact that TMS backed up the SET District rep's story this time does not infer that they back the dealer 100% of the time- in fact it's only indicative that they they backed the dealer in this particular case, nothing more, nothing less.
You should make sure that dealership is properly rewarded by both word-of-mouth and a written letter to the Service Manager, Fixed Ops Director (if applicable), the General Manager, the Owner and of course, your friendly District Rep.
You should also go the extra mile in getting your normal service done by them, and referring customers to them. Making sure word gets out about a good dealer is just as important as getting word out about a bad one.
I would hope you pursue commending them with the same zeal you had condemning the others... your story can have an impact and perhaps force change, and furthermore, you need to recognize that the same District Rep may cover this store, therefore possibly denying payment for them and forcing them to eat it. Knowing SET, it wouldn't surprise me at all.
Glad things worked out in the end for you...![]()
I think the last aspect of this thread is the most ignored. I have NO WARRANTY on any of my trucks and I still take my trucks to Cherokee Toyota here in Atlanta. Why? Because I know I will be buying a new Toyota some day, and I want that relationship. I negotiate my labor rates, total costs, etc on things they do to my trucks (mostly coolant, oil, etc work). I know the service manager, parts manager, etc. by simply being there and starting up conversations about "that big land cruiser"....why?
Relationships and understanding. They know what I do. They know I take care of my junk. If I bring something in I can talk about it technically and intelligently. I suspect the only way I would be denied a warranty claim (once I have one) would be if they had a volume issue one month.
For the record...I have replaced a set of front axles, a set of rear axles, a rear diff, a front ring and pinion set, a rear locker, and a lot of other stuff on my 80 with no warranty help from anyone...I wheel it, I break it, I fix it. I know what I am getting into and what can happen. A warranty is meant to help with this on a new vehicle, but honestly it is meant to cover manufacturing flaws (this R&P falls into this category IMHO) and other unforeseen issues with design.
I know they show these lil buggers on rocks all over the place, it makes it a hard call. So what happens when the R&P gets replaced and it breaks again? Since it was a new part number, properly hardened, etc. your going to have a harder time claiming it wasn't abuse...unless you want to lock horns with the design on using that size diff on that size truck, etc.
Slippery slope is all I am saying. I have helped several trucks with this issue now, and always will. I wish everyone with the problem good luck. I can also say that taking those damn things apart so they will roll home sucks
Oh, and remember: It isn't always about trying till you get resolution as much as knowing the right people for the right amount of time so they will go to bat for you.
I've wheeled w/ FJCRUZR and I wish I treated my junk as gently as he treats his. I agree that when you go off road you risk breakage and that is your responsibility to fix unless the part is defective which seems to be the case here.
On my list however in the future, is a switch to ARB lockers in the... rear for added strength.
I believe because there are not many ARB's(zero) available for a 8" rear when there is a factory e-locker involved.
I thought the housing size was different on a e-locker rear than a non-locker rear therefore needing an axle swap and not just the 3rd member?You have to change out the entire 3rd member to do it. A good many people have already done this modification....![]()
