I wish I could afford something like this, I'm not far from your shop at all.
Fraglerock said:I wish I could afford something like this, I'm not far from your shop at all.
Panhard at the frame side is a major pain in the butt, should have that one done in two weeks.
The amount of space available is very narrow and has made me get creative on the bracket design.
Thanks for the update! Can you give us any other details at this point?
What link setup and design did you end up going with for the front (Y, 3, or 4-link)? And will 2.5 coilovers with reservoirs work with the setup? Would 2.5 coilovers also allow the panhard setup to be easier?
Have you found a good swaybar solution? Most seem to struggle with this.
Where are you headed with the rear? Longer 4-link with coils or something else?
What size lift will it end up being and what size tires will go on the test rig?
Looking forward to seeing more and finding out when this will be available for the rest of us. If it is a great on-road and off-road setup, I hope to be a future buyer soon!
Would this system you are working on be compatible with a one ton axle swap?
The upper tower link bracket or are you modifying the panhard bracket?
