Broken bumper bracket p/n? (4 Viewers)
the driver side portion of my rear bumper is sagging and doesn't stay in the "clips" on the side.
I noticed that this portion of the bracket holding the bumper is broken:
Is that part of this piece on the diagram?
Thanks!
Here's a pic of the rear 3/4 view with the rear fascia removed so you can see what's underneath.
Looks like part number 52563-60050 and the clip you circled inserts into the hole marked by red arrow.
@urinalcake got you covered and I believe he's correct in regards to the actual part you need.
If you also need this bracket that's more along the side, it's 52156-60070
thank you both for the help!
the part was under the rear combination lamp diagram...i would've never figured that out
Is the bumper support bracket that keeps the rear bumper tight against the rear quarter panel a one-and-done part? My passenger side bumper support needs to be replaced- no longer locks in the bumper cover where it meets the wheel well. Since I have to pull the bumper cover to replace it, wondering if I should replace driver side also? Or, maybe I’ll be able to just pull back passenger side without remove entire cover? Never pulled a rear cover on one of these before. Thanks for any advice.
