HDJdreams
I have had unimpressive brake performance for the last several years.
I just went through my rear axle (which was leaking gear oil all over the drivers side) replacing bearings, seals, parking shoes, rotors, calipers (because one leaked as I pushed the piston back in), pads, and Slee stainless steel lines. I thoroughly vacuum bled the rear system including LSPV until clear fluid came out consistently.
Sadly it didn't make any difference.
As I started on the front axle to replace the brakelines and bleed, I noticed that the passenger inside pad was almost worn down to the metal scraper while the passenger outside and both driver's side pad are thick and look basically new. The rotors are still plenty thick and smooth/flat (no grooves).
Surprised at the uneven pad wear. Does this mean that the piston seals inside my 20 year old original OEM calipers are shot?
