I think you are good to go. As long as you get a good 6 or so turns into the fitting and the flares are done properly, they will conform to the inner flare and seal up.
In the last pic , the flare's secondary step isn't down far enough - hence the lip that formed when installed into the cylinder . I've never heard of any of the fittings on these things being the ISO metric bubble flare , anyone care to clear that up ?
The two bumps from the clamp's frame gap is a non-issue , the tubing will conform to the insert in the female hole when you tighten down the nut . If you want to test a fitting , use a clutch master and an old brake cylinder captured in a vise - just make sure to cover it with a rag to prevent any cracks from jetting brake fluid into your eyes or anything valuable .
Sarge
Great pics kruisinkid. Rick, in your pics showing the fully threaded Toyota nut, the nut is bottomed out externally before reaching the required depth to seal. Another thing you need to examine closely is that your mix of componenets will most likely have a mix of what flare is required so a line could have a double flare on one end and a bubble flare the other, and yes, there are bubble flares on these trucks. Double flares had a tendancy to split the nut when overtightened making removal a pain.
Exactly where are there bubble flares on these trucks?
I too have only heard of the FJ40 having double flares. Also, and please chime in here with other known line nuts on other years, my project is a May '77 and all the line nuts are completely threaded. I tried a shouldered nut and it only threads two rows.
Are you coming down to the swap meet?
Okay. Talking to a professional of over 40 years but not necessarily familiar with Japanese lines, he believes there is most likely a difference in the nuts when mated with master cylinders. After our talk, I looked into it and see that the female threads are deeper in the master cylinder than in the drums for instance. So, the reason for the confusion may be that there originally may have been a mix of both. If an FJ40 somewhere in the world still has all of the original lines we just may find out but that may be unlikely. So I would prefer shouldered lines in the deep holes, threaded nuts in the shallower holes.
