Brake Controller for 2018 GX460 Luxury (3 Viewers)
This one matches with a switch bezel (sold separately) that will fit into one of the GX's blanks on the dash.
Or this one:
Amazon product ASIN B000P17NXQ
ok cool, do you know if I have to run a seperate wire for the brakes back to the connector? I have a factory hitch and wiring.
I believe this is true for both (I have the Redarc installed), but the unit comes with a pig tail that you need to splice into your factory brake controller pigtail that should have come with your GX if you have the tow package installed (it's usually in your glove box, or maybe in the rear in one of the cubbies). Splice these two harnesses together (4 wires), and then plug the GX end into the harness down by the dead pedal/kick panel on the left side. You can see it below in the upper left of the pic - the white harness by the ebrake.
If you don't have the GX pigtail in your glovebox, then you'll need to source that as well.
I believe this is true for both (I have the Redarc installed), but the unit comes with a pig tail that you need to splice into your factory pigtail (Do you have a picture of this?) that should have come with your GX if you have the tow package installed (it's usually in your glove box, or maybe in the rear in one of the cubbies). Splice these two harnesses together (4 wires) (What harnessnes? The ones at the hitch I assume?) , and then plug the GX end into the harness down by the dead pedal/kick panel on the left side. You can see it below in the upper left - the white harness by the ebrake.
I might have found a picture online that is starting to makes sense... :)
(I created a picture tutorial below)
I’ve had good results with Tekonsha over the years.
So I purchased the redarc controller and have the Lexus pigtail. Couple extra wires on the Lexus side.... I noticed the Toyota pigtail that redarc sells has a white wire with a eyelet attached to it.... Any suggestions or diagrams?
I found that for reference if it helps someone in the future.
I've been investigating the same thing in preparation for a 2000 mile road trip this summer towing a ~5k-6k lbs trailer. I found this video on YT with full install instructions. Looks pretty comprehensive. This guy has a bunch of tutorials on projects he did on his 460.
  • Like
Reactions: r2m
Would mind posting this also in the "Manuals" thread? GX 460 Manuals
It would be a lot easier for people to find when needed.
Thank you from all of us!!
Very nice step by step.
Drilling the hole in the kick board, no issues with air-bags or their possible deployment?
